ScheduleFilter using y/n
Long time no see, forum,
Problematic node: ScheduleFilter.ByFielsTypeAndValue
What I expected: Creation of filters that could be used to deal with yes/no parameter
What I got:
  • Impossible to cast ‘System.Boolean’ into ‘Revit.Elements.Element’.
  • Impossible to cast ‘System.Int64’ into ‘Revit.Elements.Element’.
I tried using:
Integer,
boolean,
string converted to int
value taken from a manually created filter
It used to work by using 0 and 1 as false and true. I get that it want to be fed a Revit.Elements.Element, but how do I create one? Also, the filter creation works with string, but it’s no use as the schedule itself wont take it.
2018-12-13_1618
n’est pas égal == not equal
Non == No
I’m gonna assume it’s a problem with the node.
So I just rebuilt my own in python and now it works. It’s always good to find an excuse to get better with the API.
Since I posted the question, here’s the answer:
2018-12-14_1016
# Dynamo Example
clr.AddReference('RevitAPI')
# RevitServices
# doc and uiapp
app = uiapp.Application
Views = IN[0]
FieldId = IN[1]
Value = IN[2]
Filters = list()
for Id in FieldId:
F = ScheduleFilter( ScheduleFieldId( Id ), ScheduleFilterType.NotEqual, Value )
Filters.append(F)
TransactionManager.Instance.EnsureInTransaction( doc )
for View, Filter in zip( Views, Filters):
( UnwrapElement( View ).Definition ).InsertFilter( Filter,0 )
OUT = IN[0]
