Just a beginner to Dynamo. If it is an unwise query please apologize.
An element (Data Device) placed on the Linked Revit architectural Door. Can we get the door parameter value to write the element (Data Device) parameter?
Thanks. bit
Yes you need to query elements in the linked model. There are several ways to do this, the best of which will depend on your exact needs and exactly what you’re starting with.
As a start, run through the entire dynamo primer, skipping no exercises. The stuff you learn here will form an excellent foundation to build on:
Then try and accomplish this task with the help of some forum posts found via the search feature:
https://forum.dynamobim.com/search?q=Elements%20from%20linked%20model%20
Post numbers two and three on that search look rather promising as starting points.
