I’m dealing with an issue conserning the 3D workspace inside of dynamo that’s not displaying in a 3D manner as it should.
Note: my dynamo version is : ( Dynamo core: 2.5.0.7460 and Dynamo Revit : 2.5.0.7586 )
I’ve tried switching between my 2 GPU’s (integrated/dedicted) but it didn’t solve it.
I’ve also tried adding revit/dynamo inside of nvidia’s 3D options section and nothing happened.
one common thing that I’m frustrated by is that the 3D background display option inside of dynamo is unclikable. (check image for refrence)
I’m hoping that I get an explanation of why I’m dealing with such problems and if you can provide some solutions to the issue mentioned in my post.
Thank you!! my issue is solved by following your approach and forcing installation of directX 10 above directX 12 (I believe that the issue is related to windows 11 installed on my new laptop, because I did not have this problem on my old laptop with windows7 installed).
