Can we extract these info using the dynamo and populate it to individual shared parameters? I want to do this in order to create a schedule where everyone can check whether their contents are modeled with proper information or not.
Sorry. I am not familiar with Revit API. I am also not much familiar with Dynamo. I tied only the default dynamo code at basic level.
I am using RFTools for Revit which gets this info for all the items. I can use the addin and populate those info to another shared parameter and write it back to my revit file. In order to do this i need to open each and every file and do it.
I am thinking to do the same with dynamo script. So i can ask any user to run the script on the file which he is working on. This will help me not to open every file.
We are working on shared project. When i use this script it is checking the whole project and updating the information. This is fine when only one person has full access to all the elemts.
The problem is we have 5+ users working on the same file, if anyone of them create any element while the dynamo is running it gives error unable to make the element editable / element request and stops the whole update.
Is there a way to run the dynamo and look for the elements owned by that user & free elements which can be borrowed by the same user. And, It should ignore the elements owned by others? This way anyone can run the addin and update the model without stopping others from working on the file.
