Create Shared parameters from excel with multiple categories and tooltip
I’m trying to combine @Kulkul, @Chandrasekar_Rajaman and @alejandro.daras work in this topics
In fact, I’m trying to generate Shared Parameters in a Revit file, and create project parameters on multiple categories same that this old post .
I tried the following solution duplicating the parameters in a second column but the script does’nt understand the second One as the parameters already exists.
Is there a syntax that could help to do this ? This is quite efficient as we can create an Excel file from a Mindmap with all parameters informations.
Example from an Xmind file :
Eventually, If there is a method to also access to the tooltip from the same File it would be great (as asked here )
