Workset Editability
Hi all, just wondering if there is any custom node or scripts that could toggle the workset editability? Basically i need to lock some workset so that my guys wont be able to edit it.
any help is appreciated :slight_smile:
So basically, the code below is what i came out with, which i will like temporary rename my workset name to get it “lock” under my name but it has an error that says no transaction is open at the moment, mind looking through my scripts? thanks
# Import Element wrapper extension methods
# Import geometry conversion extension methods
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
if isinstance(IN[0], list):
files = IN[0]
files = [IN[0]]
typelist= []
TransactionManager.Instance.ForceCloseTransaction()
for file in files:
newdoc = app.OpenDocumentFile(file)
TransactionManager.Instance.EnsureInTransaction(newdoc)
Viewwss = FilteredWorksetCollector(newdoc).OfKind(WorksetKind.ViewWorkset)
Viewwss_ns = [Viewws.Name for Viewws in Viewwss]
Userwss = FilteredWorksetCollector(newdoc).OfKind(WorksetKind.UserWorkset)
Userwss_ns = [Userws.Name for Userws in Userwss]
for View_ws,View_ws_n in zip(Viewwss,Viewwss_ns):
if "02_RVT LINK_" in View_ws_n:
Autodesk.Revit.DB.Transaction(newdoc, "Rename_Workset").Start
WorksetTable.RenameWorkset(newdoc,View_ws.Id,View_ws_n + "1");
WorksetTable.RenameWorkset(newdoc,View_ws.Id,View_ws_n);
Autodesk.Revit.DB.Transaction(newdoc).Commit
continue
typelist.append([newdoc,Viewwss,Viewwss_ns,Userwss,Userwss_ns])
OUT = typelist
Sorry with the coding format, didnt know what is wrong with it…
FWIW, every time I’ve seen a method used to ‘lock out’ worksets I’ve seen a resulting corruption issue leading to downtime and/or data loss. Permanently locking worksets isn’t something I would recommend as a result. Copy monitor, pinning elements, and utilizing links are all vastly more stable.
Anyway what does “FWIW” means?
I can agree with you to a certain extend but as a company with internal and external modelers/drafters, i do feel the importance of locking certain worksets, for example revit links and certain sets of view template.
With BIM technologies advancing so rapidly, clients had request for model upgrades to keep up with the availability of technologies, hence my query on this topic.
I do hope that someone could enlighten me with this topic.
FWIW = For what it’s worth
A little update, so i have found out a way to hold onto worksets via “WorksharingUtils.CheckoutWorksets” from the revit API. However I am having this error and have no clue onto how to proceed on with the scripts. Below is the screenshot of my graphs(with error) and the script i had used.
# Import RevitAPI
IDs = IN[0]
Names = IN[1]
IDs = [IN[0]]
Names = [IN[1]]
typelist,checkedout_ws= [], []
checkedout_ws = WorksharingUtils.CheckoutWorksets(doc,IDs)
typelist.append([Names, checkedout_ws])
OUT = typelist
So i tried adding a for loop into the script and i got this error
# Import RevitAPI
IDs = IN[0]
Names = IN[1]
IDs = [IN[0]]
Names = [IN[1]]
for ID in IDs:
checkedout_ws = WorksharingUtils.CheckoutWorksets(doc,ID)
OUT = typelist
The main problem is that you are inserting a dynamo type into a command that needs a Revit type. You have to unwrap the object in order to use with API.
UnwrapElement(putObjectHere)
and then it can be used with the commands. Although I don’t know the output of Workset.Id as a node, but it looks like it returns an int. A better way might be to use the Select.GetAllWorksetByKind’s workset output, bring it into Python, UnwrapElement(workset).Id and use that as the checkedout_ws = WorksharingUtils.CheckoutWorksets(doc,IDs)'s IDs
Hey @kennyb6
i followed your advise and there is still an error, but this time it says contain worksetID. See below’s screenshot and code
# Import RevitAPI
Wss = IN[0]
Wss = [IN[0]]
for ws in UnwrapElement(Wss):
Userwss_ns = ws.Name
Userwss_id = ws.Id
checkedout_ws = WorksharingUtils.CheckoutWorksets(doc,Userwss_id)
typelist.append([Userwss_ns, checkedout_ws])
OUT = typelist
Oh I remember that error now. Instead of going thru the list, it wants the list itself, but as an ICollection which is not the same as Python’s lists, if I remember correctly. Try following this thread and see if it works: How to create an icollection to work with revit api
Try adding the following references to the top:
clr.AddReference(“System”)
Then put in:
ws = List[WorksetId](UnwrapElement(Wss))
and use ws in WorksharingUtils.CheckoutWorksets(doc,ws)
Might need to mess with the unwrapping or looping if that doesn’t work right away.
thank you @kennyb6.
my issue have been solved :slight_smile: Do you want me to post the codes here for your future reference?
Sure! It can help out others too who come across the same issue.
@kennyb6 there you go :slight_smile:
# Import RevitAPI
# Import system library
clr.AddReference('System.Core')
	newdocs = UnwrapElement(IN[0])
	IDs = UnwrapElement(IN[1])
	Names = UnwrapElement(IN[2])
	newdocs = UnwrapElement([IN[0]])
	IDs = UnwrapElement([IN[1]])
	Names = UnwrapElement([IN[2]])
typelist, iDs = [],[]
try:
	if IN[3]:
		x = 0
		for newdoc in newdocs:
			iDs = IDs[x]
			names = Names[x]
			Ids = List[WorksetId](iDs)
			try:
				checkedout_ws = WorksharingUtils.CheckoutWorksets(newdoc,Ids)
				typelist.append([newdoc,names,checkedout_ws])
			except Exception,e:
				typelist.append(str(e))
			x=x+1
		typelist.append("Please toggle to True to continue this process")
except Exception,e:
OUT = typelist
I’m getting an error :
File “”, line 35, in
IndexError: index out of range: 1
Kindly assist…
i think it is because you are feeding a single file. And at that point of me posting my code, im still a python noobie. :smiley: so the new and improve code will be like this.
# Import RevitAPI
def ToList(x):
    if isinstance(x,list):
        return UnwrapElement(x)
        return [UnwrapElement(x)]
newdocs= ToList(IN[0])
worksets = ToList(IN[1])
typelist = []
for newdoc,workset in zip(newdocs,worksets):
    IDs = [ws.Id for ws in workset ]
    Ids = List[WorksetId](IDs)
    try:
    except Exception,e:
        checkedout_ws = str(e)
    typelist.append(checkedout_ws)
OUT = typelist
EDIT: try this instead, i remembered the type of list structured that is required for this script to work
Thanks will try this out.
I’m getting this error now :
unindent does not match any outer indentation level
basically your IN[0] is the document and IN[1] is the worksets you want to checkout in each document
maybe you can show me your workflow, then i can try my best to cater to above code to your needs. Cause my codes are based on my specific workflow which might not be suitable for your case
I re-create this code and put your revised phyton code
