Make Worksets Editable
Hi, is it possible to make a workset editable? I am trying to delete a workset, and the delete worksets node from Genius Loci is what I need, but it cannot delete noneditable worksets…
Hi @ChrisGamble
try this version
#Alban de Chasteigner 2021
#twitter : @geniusloci_bim
#geniusloci.bim@gmail.com
#https://github.com/albandechasteigner/GeniusLociForDynamo
# updated by Cyril Poupin 08/12/2024
import sys
import System
from System.Collections.Generic import List, IList, Dictionary
# Import RevitAPI
clr.AddReference("RevitAPI")
deleteIds = IN[0] if isinstance(IN[0],list) else [IN[0]]
option = IN[1]
destinationIds = IN[2] if isinstance(IN[2],list) else [IN[2]]
names = []
# ensure convert to List<WorksetId>
destinationIds = List[WorksetId]([x if isinstance(x, WorksetId) else WorksetId(x) for x in destinationIds])
deleteIds = List[WorksetId]([x if isinstance(x, WorksetId) else WorksetId(x) for x in deleteIds])
TransactionManager.Instance.ForceCloseTransaction()
# set Worksets editables
destinationIds = WorksharingUtils.CheckoutWorksets(doc, destinationIds)
deleteIds = WorksharingUtils.CheckoutWorksets(doc, deleteIds)
doc.Regenerate()
if option == "MoveElementsToWorkset" :
    deleteWorksetSettings = DeleteWorksetSettings()
    deleteWorksetSettings.DeleteWorksetOption = DeleteWorksetOption.MoveElementsToWorkset
    deleteWorksetSettings.WorksetId = destinationIds[0]
for worksetId in deleteIds :
    if WorksetTable.CanDeleteWorkset(doc, worksetId, deleteWorksetSettings):
        WorksetTable.DeleteWorkset(doc, worksetId, deleteWorksetSettings)
        names.append(doc.GetWorksetTable().GetWorkset(worksetId).Name)
        names.append("The workset is not editable by the current user or is owned by other user")
if isinstance(IN[0], list): OUT = names
else: OUT = names[0]
The CheckoutWorksets method also returns the Ids of all now and previously editable worksets provided to it I believe, which might simplify the logic of the process should you ever deal with lists of worksets to delete/move elements to. In the case of the above scenario you would also know that if the returned list has less than 2 objects, the process can not proceed.
fixed, thanks :grinning:
