Workset Editability
yea because the list of structure for that code doesnt work with that. My final product is to open multiple documents and checkout worksets with a specific naming convention. If you just want to checkout workset in current opened document then the code below should work.
# Import Element wrapper extension methods
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
# Import system library
clr.AddReference('System.Core')
app = uiapp.Application
def ToList(x):
    if isinstance(x,list):
        return UnwrapElement(x)
        return [UnwrapElement(x)]
worksets = ToList(IN[0])
iDs = [ws.Id for ws in worksets]
Ids = List[WorksetId](iDs)
try: checkedout_ws = WorksharingUtils.CheckoutWorksets(doc,Ids)
except Exception,e: checkedout_ws = str(e)
OUT = checkedout_ws
Do i need 2 IN?
nope dont need. just one. can check what is the error showing? because the code are all typed here manually. so i might have missed some indent
Noted. here’s the error :
File “”, line 39, in
AttributeError: ‘str’ object has no attribute ‘Id’
ah, you are feeding the wrong input, feed the document.worksets output to the input of List.filterbyboolmask
and also set lacing of list.contain item to longest
see my post carefully
oh, lacing?
I set it to longest now…still getting same error.
look carefully at my previous post, you are feeding wrong input to the List.FilterByBoolMask node
My bad! i wire the filtering to the Workset.Kind
working properly now…
Thank you so much!
no worries man. glad to be able to help you
@stillgotme
I want to achieve the opposite, that all User Create Worksets are converted to non-editable. How do I do this, I have no experience with Phyton scipting. Who has a solution for this?
Thanks in advance.
this post has exactly what you want
@stillgotme,
Hi, I find the code for Editable but not the code for Non-Editable.
How can I set my Workset to Non-Editable.
Thanks in advane.
i think you can just check out again using the same command???
I used this code in my script and edited to non editable and it doesn’t seem to work for me, can anyone help
NON EDITABLE api functions are read only, not sure if this has chganged but looking for work arounds
what’s then?
sorry for stupid question
hi, i tried this one (final product) but didnt work for me . please let me know
# Import RevitAPI
def ToList(x):
OUT = checkedout_ws
I believe we spoke about this one via Linkedin, apologies for saying it cant be done - looks like the Utils class is a workaround.
Try below, this should work in IronPython2:
from Autodesk.Revit.DB import WorksetId, WorksharingUtils
def uwList(x):
worksets = uwList(IN[0])
wsIds = List[WorksetId]()
for w in worksets:
	wsIds.Add(w.Id)
try:
	WorksharingUtils.CheckoutWorksets(doc, wsIds)
	OUT = True
except:
	OUT = False
Yes, we discussed, I tried but still am getting errors so i attached file, can u check it and let me know. [Dynamo version 2.19.3]
Workset project info.dyn (17.5 KB)
