Hey Everyone,
Newish to dynamo and python, found this script that sets worksets to non editable.
I’m trying to add it to a larger script that can set up new files for projects. Makes a new file a workshare file, creats worksets, set them all as non ediable and seting some as non visible, and each time you open the project file you need to set your workset.
Here’s the script thats giving me errors tick non edibatble
# Import Element wrapper extension methods
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
# Import system library
clr.AddReference('System.Core')
app = uiapp.Application
def ToList(x):
if isinstance(x,list):
return UnwrapElement(x)
return [UnwrapElement(x)]
worksets = ToList(IN[0])
iDs = [ws.Id for ws in worksets]
Ids = List[WorksetId](iDs)
try: checkedout_ws = WorksharingUtils.CheckoutWorksets(doc,Ids)
except Exception,e: checkedout_ws = str(e)
OUT = checkedout_ws
