Hello Dynamo friends
I want to build a WinForm that displays a list of keys, lets me make a selection and gives the values as a result. I found the following thread and stole some code from @c.poupin
Hi all,
I try to write a script that give me a UI with a checkbox.
But the input is a list, how can I do it inside a class / def?
[image]
import clr #.NET Laden
import sys #sys is de fundamentele Python bibliotheek
#de standaard IronPython-bibliotheken
sys.path.append(r'H:\BIM-REVIT\00 GEBRUIKERSGROEP BIM\00 BRONBESTANDEN\Python\defs') #Imports the
#standaard IronPython-bibliotheken, die alles dekken, van servers en
#encryptie tot reguliere expressies.
import functies as fc
import System #T…
This code gives me just the keys as output, so i wrote a piece of code that gets the values from there.
KeyList = IN[0]
ValueList = IN[1]
Selection = IN[2]
Result=[]
for i in Selection:
Index = KeyList.index(i)
Value = ValueList[Index]
Result.append(Value)
OUT = Result
My problem is now that i can´t get this to work in a single python node because my WinForm output seems to be a collection and not a list So how can i make a list out of it?
import sys
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class Form24(Form):
def __init__(self, lstSchedule):
self._lstSchedule = lstSchedule
self.out = []
self.InitializeComponent()
def InitializeComponent(self):
self._checkedListBox1 = System.Windows.Forms.CheckedListBox()
self._checkBoxSelectAll = System.Windows.Forms.CheckBox()
self._button1 = System.Windows.Forms.Button()
self.SuspendLayout()
# checkedListBox1
self._checkedListBox1.Anchor = System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Right
self._checkedListBox1.FormattingEnabled = True
self._checkedListBox1.CheckOnClick = True
self._checkedListBox1.Location = System.Drawing.Point(12, 30)
self._checkedListBox1.Name = "checkedListBox1"
self._checkedListBox1.DataSource = self._lstSchedule
#self._checkedListBox1.Items.AddRange(System.Array[System.Object](self._lstSchedule))
self._checkedListBox1.DisplayMember = "Name"
self._checkedListBox1.Size = System.Drawing.Size(260, 244)
self._checkedListBox1.TabIndex = 0
# checkBoxSelectAll
self._checkBoxSelectAll.Anchor = System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left
self._checkBoxSelectAll.Location = System.Drawing.Point(12, 291)
self._checkBoxSelectAll.Name = "checkBoxSelectAll"
self._checkBoxSelectAll.Size = System.Drawing.Size(104, 24)
self._checkBoxSelectAll.TabIndex = 1
self._checkBoxSelectAll.Text = "All/None"
self._checkBoxSelectAll.UseVisualStyleBackColor = True
self._checkBoxSelectAll.CheckedChanged += self.CheckBoxSelectAllCheckedChanged
# button1
self._button1.Anchor = System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right
self._button1.Location = System.Drawing.Point(191, 289)
self._button1.Name = "button1"
self._button1.Size = System.Drawing.Size(75, 27)
self._button1.TabIndex = 2
self._button1.Text = "OK"
self._button1.UseVisualStyleBackColor = True
self._button1.Click += self.Button1Click
# Form24
self.ClientSize = System.Drawing.Size(284, 334)
self.Controls.Add(self._button1)
self.Controls.Add(self._checkBoxSelectAll)
self.Controls.Add(self._checkedListBox1)
self.Name = "Title"
self.Text = "Title"
self.ResumeLayout(False)
def CheckBoxSelectAllCheckedChanged(self, sender, e):
for i in range(self._checkedListBox1.Items.Count):
self._checkedListBox1.SetItemChecked(i, sender.Checked)
def Button1Click(self, sender, e):
self.out = self._checkedListBox1.CheckedItems
self.Close()
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstSchedules = toList(UnwrapElement(IN[0]))
ValueList = toList(UnwrapElement(IN[1]))
objForm = Form24(lstSchedules)
objForm.ShowDialog()
KeyList = objForm.out
Result=[]
for Key in KeyList:
Index = KeyList.index(Key)
OUT = Result
Hi @gerhard.p ,
I don’t understand what you trying to do.
Do you need the outputs of the selected values?
Hello Jan,
i want to do the standard key/value thing, like datashapes does it.
Here an example with RibbonTabs as values and names as keys:
Keys are just used to identify the values, i want to get the corresponding value (RibbonTab) as output.
As cirils code only got me the “keys” as output I wanted to use get index and get item at index methods to get my values, but there for sure must be a better way? I searched through the datashapes code but couldn´t find what i need.
you can use a dictionary or a DataTable
example
import sys
clr.AddReference('System.Data')
from System.Data import *
class Form24(Form):
def __init__(self, lstSchedule, lstValue):
self._tableData = DataTable("Data")
self._tableData.Columns.Add("Key", System.String)
self._tableData.Columns.Add("Value", System.Object)
# populate dataTable
[self._tableData.Rows.Add(key_, value_ ) for key_, value_ in zip(lstSchedule, lstValue)]
self.out = []
# checkedListBox1
self._checkedListBox1.DataSource = self._tableData
self._checkedListBox1.DisplayMember = "Key"
# checkBoxSelectAll
# button1
# Form24
self.Name = "Title"
self.Text = "Title"
self.out = [row['Value'] for row in self._checkedListBox1.CheckedItems]
self.Close()
objForm = Form24(lstSchedules, ValueList)
Result = objForm.out
OUT = Result
Note:
pay attention currently hasattr(x, '__iter__') does not work well with Cpython3/Pythonnet
Hello Cyril,
OK, you created a table with rows and columns, and then filled the rows with the keys and values which are zipped together. In the end you get the value for every checked row. Thank you very much!
I changed the inputs to avoid problems with the “iter” function:
if isinstance(IN[0],list):
lstSchedules = UnwrapElement(IN[0])
lstSchedules = [UnwrapElement(IN[0])]
if isinstance(IN[1],list):
ValueList = UnwrapElement(IN[1])
ValueList = [UnwrapElement(IN[1])]
OUT = Result
