Alien
January 9, 2024, 10:09am
1
Yesterday I thought I’d get round to updating some nodes for my companies package.
But my nodes don’t show up in Dynamo.
Why not?
You can see the node, “ReportUseR23” is in the folder that is one of the default locations for Dynamo to look at.
If I click on, “show root directory” next to the package name it takes me to that folder where that node does not exist.
What’s happening and how do I fix it?
I tried turning it off and on again…
Alien
January 9, 2024, 1:17pm
2
After trying approx. 1 million things I gave up and simply made the node again.
I would like to know why this happened though if anyone knows.
If you are willing to share here, or in a DM then we can take a look at why it’s failing
Alien
January 9, 2024, 4:55pm
4
I would but I deleted the offending node and created a brand new one.
I did a ‘save as’ originally, could this be the issue?
Most likely. A Save As only changes the file name and location but none of the other meta data in the dyf, including node name and references. You either need to edit the file to manually change those values or copy/paste all your node contents to a new workspace to save as a brand new file.
