mix
December 30, 2020, 7:33pm
1
Hello, I have tried multiple times to get the watch 3D to work but it is not. I have Revit 2019 and dynamo 1.3.4. Is there something I can do to fix this? I read the other posts but there doesnt seem to be a solution yet. Please advise. thanks!
You might have a graphic card or driver problem since the Node does not show anything. Did it work in other graphs?
Maybe you find some information here that will help you:
I’m trying to learn Dynamo (just started tutorials yesterday.) I can’t get the background preview to work, or get the Watch 3D to work, or see anything happening in the Revit workspace. What am I doing wrong?[Capture]
Hi guys,
I am having graphics issues. When I place a node to obtain some 3D object like a cylinder, cone, etc, the 3D background turns into half of the available workspace. As you can see, in capture 1 everything is good but when I connect Cylinder.ByRadius node, the workspace reduces to half (see capture 2). And the same happens when I connect the node Cone.ByPoint. I think the problem is when I try to reproduce a 3D surface.
capt1
[001]
capt2
[002]
cap3
[003]
I am really sure that …
