Warning for the Node Rebar.Perpendicular
Hello everyone,
i get the following warning when using the node rebar.perpendicular:
Warning: Your inputs lie outside of the allowable modeling range, consider choosing the Extra Large setting with a modeling range between 1 and 100,000,000 from the “Settings => Geometry Working Range” Dialog
I already set the geometry working range to extra large and it’s still not working. Can anyone help?
Thanks!
Hi @laurin.ernstMA6Q3
After setting to extra large are you getting same error ( Warning: Your inputs lie outside of the allowable modeling range, consider choosing the Extra Large setting with a modeling range between 1 and 100,000,000 from the “Settings => Geometry Working Range” Dialog)?
And also after setting working range did you try restarting dynamo?
Hi @Kulkul
thanks for the help.
Yes still the same warning and i also closed Dynamo und opened it again.
Do you want to have a look?
Laurin
Thank you so much @Kulkul for guiding me through PM. The issue is solved now. I didn’t input all of the nodes. The script is running :slight_smile:
Excuse me, could you explain better what did you do to solve this issue. I’m facing the same problem and the rebar that I’m putting in my solid will go endlessly in one direction. On the other side, the selection of the starting point works well.
Thanks!
