Dear All,
I have dynamo script to place views on sheets.
This dynamo script work perfectly in Revit 2018 but in Revit 2020 showing error at custom node.
I have attached here images for reference.
Please advice.
Thank you.
SteamNodes last update was in January 2018, so you need to fix that error yourself. Just read the message and change the input name into something that is not a Variable already defined in the Dynamo environment.
Alternatively, switch to another package/node that places a Viewport on a Sheet, there are multiple alternatives once you search for a bit.
Dear Bjorn,
Thank you for your advice.
I used another node from ‘Rhythm’ package.
