I am using Rhythms Walls.HasEditedProfile node and it seems to be removing dimension overrides. Not sure why. Has anyone else had this problem?
This is the warning I got when I Ran it.
that being said, Revit 2018.1 + has the method “GetDependentElements” and I should be able to pivot to that. Let me get that updated in the next version.
Thanks yet again for the quick reply. Also, thank you for the extra mile with the code samples.
I have also used the Temporary transaction method. It is interesting that Revit kicked out an error before the transaction could be rolled back (if I am not mistaken). This solved another problem I was having where nodes in my larger graph were failing due to a transaction already being open. I think when Revit errored out the transaction did not close properly and prevented the other nodes from opening their transaction.
Any way just downloaded your update and it is working great.
