Reset Profiles on Walls
Hello all,
I’m working on Revit 2022, and I was hoping I could use the API methods that were introduced in this version to modify Wall Profiles. I’m mostly interested in accessing the RemoveProfileSketch Method
However I haven’t been able to find a node that does this.
How difficult would it be to write one? One that takes an Element input and applies the action to it.
If it’s a simple syntax, could you give me hand?
If it’s more involved than that, what similar nodes could I look into as an example?
(I’m about to get into studying Python and the Revit API. This is both a problem I need to solve and a learning experience.)
Thanks in advance for any leads.
Hello @Nicolas.Rivera and welcome
here an example
reset Wall
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstelems = toList(UnwrapElement(IN[0]))
for e in lstelems:
	if isinstance(e, DB.Wall):
		e.RemoveProfileSketch()
OUT = lstelems
Thank you very much @c.poupin!
It works exactly as expected, and now I have a template for future reference on how to call individual API actions. This helps me a lot. Thank you very much!
