Hi all,
I’ve been asked to model in skirtings to every room of a project (fun stuff), so was looking at a way of automating the placing of wall sweeps.
I can select a room, extract the walls that act as bounding elements, and create a sweep to these as shown (using the Data-Shapes WallSweepOnWall node) but as you can see from my example, it’s creating the sweep on the wrong side of the wall.
How can I control which face of the wall it applies to? The input of the node accepts walls, not faces.
After a bit more fiddling, I’ve determined it applies it to the Exterior side of the wall.
Hi @dan.buckingham you could try with element mirror or set location…
Thanks, that would appear to work, but it would cause issues when working with 2 adjoining rooms I feel.
I’m now changing approach, away from wall sweeps and instead placing line based families at room boundaries
allright and you are right wallsweep will always follow the wall not the rooms…good luck
Hi @sovitek I would like to see the Dynamo File or all the images.
Thank You
sovitek
February 18, 2025, 6:24am
7
sorry dont have it anymore
Will be very good for me
Thank you
sovitek
February 18, 2025, 7:48am
9
allright…if you play around with the same issue, then show us where you are stuck and we can try help
I want the Wall Sweep Inside Wall and in the room.
sovitek
February 18, 2025, 9:21am
12
allright i can take a look later, not at dynamo now, and probably not more today…tomorrow
sovitek
February 18, 2025, 11:39am
14
Hi @Somchai_Ch try something here…
Hi @sovitek I try to do this. I don’t know where it was wrong. Please see
Thank You
sovitek
February 19, 2025, 6:41am
16
seems you dont select the walls…try as here instead where you only need select the sweeps…
FORUM SWEEP.dyn (24.6 KB)
PS have people seen this new thing at least for me ;)…damn thats smart thx
bvs1982
February 19, 2025, 7:58am
17
@sovitek
Is it me or don’t i see the Summarize button in every topic?
sovitek
February 19, 2025, 8:01am
18
not sure…havent check every post in the forum but a nice feature
bvs1982
February 19, 2025, 8:04am
19
100% agreed. Maybe it is just for topics after a certain date?
But i guess on topic again
