Wall Structure Material
Hello
I want to make an application that selecting a wall will show you how it is structured, as shown in the first figure. The problem is that as seen in the video, I believe only one, and I can not remove the zeros in the thickness.
If I could give you an idea would be great.
Regards.
<a class=“attachment"href=”//cdck-file-uploads-us1.s3.dualstack.us-west-2.amazonaws.com/flex022/uploads/dynamobim/original/3X/1/7/17106a7aa3e43951d097e1d5e4cc2683cb21f261.dyn">Wall_Material.dyn (14.1 KB)
I wonder if this thread might help? Rounding Values
Hi @giacco
There are many ways to remove zeros from string. Here is one of the possible way.
Perfect!, Kulkul, thank you very much, I have solved the problem of removing the zeros.
Now I have two problems:
  • The first, is to indicate to dynamo in which point in the “Floor plan” I want that I put the “Text”, now it’s in (0,0,0) because it is explicitly indicated. How can I select another Insertion point by clicking directly on the Floor Plan?
  • Second, how to create multiple instances of Text, because when I select another wall, I replace the values already created in the previous selection.
Thank you very much and greetings.
wall structure.dyn (14.5 KB)
