I’m trying to create a node that will let me select walls with a certain Location Line (for example Wall Centerline), and change that to for example Core Centerline.
Thanks for the responses! I’ve changed both of them to integer and the filter part is now working, but it won’t add the new zero value (and change the Location Line to Wall Centerline).
You’re filtering the parameter value instead of the element so you’re not actually setting the Location Line for anything. The list input for FilterByBoolMask should be the list of elements.
