Wall Start and End point
Morning everyone,
im trying to find the coordinates of the start and the end of a wall to then create a line based on it. Of course i can easily list all the walls in my project but i could not find a way to track the start/end coordinates.
Any help is much appreciated… again
you need to get wall’s curve then query start and end point.
Im only finding Create curve, no Query. Am i missing something? … i know as usual yes :slight_smile:
WallCurve_A
Ok, found Curve.StartPoint and Curve.EndPoint.
I can’t pass the wall directly to them obviously, still looking to get the wall curve element… and the search goes on :slight_smile:
Thanks for the help
Ok, i used the element location to get the curve. Works fine :slight_smile:
Now onto step 2 :slight_smile:
Hi, @Daniel_Hurtubise if you have worked that out?
I’m facing the same issue as you. I want to find the start/end points of walls in the Revit model to provide data for 4D printing .
@chacha you can use Curve.StartPoint and Curve.EndPoint
