Get Start and Entpoint of a wall?
i solved it partly i get curves but i can`t convert it …
i want start and endpoint
clr.AddReference('RevitAPI')
clr.AddReference('System')
elements = UnwrapElement(IN[0])
output = []
for i in elements:
	output.append(i.Location.ToProtoType())
OUT = output
KR
Andreas
Seem like You want get it in Dynamo, so you can get from OOTB node Element.GetLocation
And if you want get by revit API Code, try this: (run with IronPython2)
output = []
for i in elements:
	output.append(i.Location)
S_points = []
E_points = []
for i in output:
	S_points.append((i.Curve.GetEndPoint(0))*304.8)#mm
	E_points.append((i.Curve.GetEndPoint(1))*304.8)#mm
OUT = S_points, E_points
In addition to what @manhgt214 provided. A couple of options for different outputs
lines=[]
curves = []
for i in elements:
	lines.append(i.Location.Curve.ToProtoType())
	curves.append(i.Location)
for c in curves:
	stpt = c.Curve.GetEndPoint(0)
	endpt = c.Curve.GetEndPoint(1)
for l in lines:
	strt = l.StartPoint
	enpt = l.EndPoint
OUT = lines, curves, stpt, endpt, strt, enpt
@manhgt214 ,
there is still some error
how can i convert the units topic with with this definition ? …insteat of using the “number”
app = uiapp.Application
def convert_cm_to_internal(length):
	rvt_year = int(app.VersionNumber)
	if rvt_year < 2022:
		from Autodesk.Revit.DB import DisplayUnitType
		return UnitUtils.Convert(length, DisplayUnitType.DUT_CENTIMETERS, DisplayUnitType.DUT_DECIMAL_FEET)
		from Autodesk.Revit.DB import UnitTypeId
		return UnitUtils.ConvertToInternalUnits(length,UnitTypeId.Centimeters)
OUT = convert_cm_to_internal(IN[0])
KR
Andreas
You’re providing elements that have a LocationPoint rather than a LocationCurve. You either need to include some way of handling those instances separately or you need to filter them out.
@Nick_Boyts ,
f.e. i go for the curves how can i get meters ?
my converting is a pit off, there should be clear 1m or 100cm
	if rvt_year < 2022:
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls)
all_walls = collector.WhereElementIsNotElementType().ToElements()
concrete_walls = [i for i in all_walls if i.Name.Contains("STB")]
curves = []
for i in concrete_walls:
S_points = []
E_points = []
for i in curves:
	S_points.append(convert_cm_to_internal(i.Curve.Length))#.#GetEndPoint(0)))#mm
	E_points.append(convert_cm_to_internal(i.Curve.Length))#.#GetEndPoint(1)))#mm
OUT =  curves, S_points, E_points
when i get for the points ?
	if rvt_year < 2022:
curves = []
S_points = []
E_points = []
for i in curves:
	S_points.append(convert_cm_to_internal(i.Curve.GetEndPoint(XYZ)))#mm
	E_points.append(convert_cm_to_internal(i.Curve.GetEndPoint(XYZ)))#mm
grafik
KR
Andreas
Are you sure the you’re using the conversion methods properly? Your code is setup to convert values in cm to your internal units, but it sounds like you’re wanting to convert to cm - is that right? From my understanding, the methods should be setup like this:
Convert(
	value, #The value to convert.
	currentUnitTypeId, #Identifier of the current unit.
	desiredUnitTypeId #Identifier of the desired unit.
	displayUnit #The value's given display unit.
Also, the GetEndPoint() method requires an index, not a type. (0 = start point, 1 = end point)
