Learn
Explore
Blog
Forum
Roadmap
Resources
Primer
Dictionary
Developer
Builds
DesignScript Guide
Help Center
Get Dynamo
Privacy
Dynamo
Wall location curve
Revit
Dimitar_Venkov
August 18, 2017, 2:03am
12
If it’s all lines, you could try the LineLoopMerge node:
1012×765 26.6 KB
1054×754 27.2 KB
Join List<Curves> to PolyCurve regardless if they are joinable
Join planar lines with Curve.Join
Bulk command to extend and close corners
Curve Sweep as Solid PROBLEM
show post in topic
Related topics
Topic
Replies
Views
Activity
Wall Location Node / Wall Exterior Location Line
Revit
6
429
October 8, 2023
Change wall location line before adding the wall so wall position changes in the beginning
Revit
20
3118
September 26, 2022
Exterior core of wall location (line / curve)
Revit
dynamo
10
1320
February 24, 2022
Create Walls by Model Lines along EXTERIOR location line
Revit
geometry
10
5606
January 28, 2021
Wall Outlines without doors / openings
Revit
python
geometry
dynamo
12
1521
July 8, 2022
