Wall finishes on linked model
Cannot get the linked elements from linked model by the following code…Got null for all values.
Does anyone have any idea?
linkedDoc.GetElement(sf.SpatialBoundaryElement.HostElementId)
seems does not work and return null.
clr.AddReference('RevitAPI')
rooms = UnwrapElement(IN[0])
linkInstance = UnwrapElement(IN[1])
linkedDoc = linkInstance.GetLinkDocument()
options = SpatialElementBoundaryOptions()
options.SpatialElementBoundaryLocation = SpatialElementBoundaryLocation.Finish
calculator = SpatialElementGeometryCalculator(linkedDoc,options)
output = []
for r in rooms:
	try:
		results = calculator.CalculateSpatialElementGeometry(r)
		solid = results.GetGeometry()
		elements = []
		for f in solid.Faces:
			#faces.append(f)
			subfaces = results.GetBoundaryFaceInfo(f)
			for sf in subfaces:
				e = linkedDoc.GetElement(sf.SpatialBoundaryElement.HostElementId)
				elements.append(e)
		output.append(elements)
	except:
		output.append(None)
OUT = elements
Hello…here is a way with nodes…
hello,
Yours rooms are local “Spatial Element” (in current model) or they are in the linked model ?
My rooms are in local model.
Walls which are bounding the rooms are from link.
Do I have to make a new SpatialElementBoundaryOptions for the link model also?
thanks! Let me try this also!
Here is an example (without input) to get linkedElement
import sys
import System
#import Revit API
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
#rooms = UnwrapElement(IN[0])
#linkInstance = UnwrapElement(IN[0])
#linkedDoc = linkInstance.GetLinkDocument()
local_room_spaces = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_MEPSpaces).WhereElementIsNotElementType().ToElements()
calculator = SpatialElementGeometryCalculator(doc,options)
output = {}
for r in local_room_spaces:
	if calculator.CanCalculateGeometry(r):
		try:
		except:
			solid = None
		if solid is not None:
			elements = []
			filter_elementIds = [] # make a filter
				for sf in subfaces:
					linkedinstance = doc.GetElement(sf.SpatialBoundaryElement.LinkInstanceId)
					if linkedinstance is not None:
						linkedDoc = linkedinstance.GetLinkDocument()
						# check if element is not already in elements
						if sf.SpatialBoundaryElement.LinkedElementId not in filter_elementIds:
							e = linkedDoc.GetElement(sf.SpatialBoundaryElement.LinkedElementId )
							elements.append(e)
							filter_elementIds.append(sf.SpatialBoundaryElement.LinkedElementId )
			output[r.Level.Name + "-" + Element.Name.GetValue(r) + "-" + r.Number] = elements
			solid.Dispose()
OUT = output
variant to get linked Materials
import sys
import System
#import Revit API
output = {}
		try:
		except:
			solid = None
			mats = []
			filter_matIds = [] # make a filter
				for sf in subfaces:
						lnk_elem = linkedDoc.GetElement(sf.SpatialBoundaryElement.LinkedElementId )
						boundingElement = sf.GetBoundingElementFace()
						materialId = boundingElement.MaterialElementId
						mat = linkedDoc.GetElement(materialId)
						# check if material i not already in elements
						if materialId not in filter_matIds:
							mats.append(mat)
							filter_matIds.append(materialId)
			output[r.Level.Name + "-" + Element.Name.GetValue(r) + "-" + r.Number] = mats
			solid.Dispose()
OUT = output
Thanks! I will try it!
sorry, got an empty list :frowning:
BuiltInCategory.OST_MEPSpaces ← I dont have this in my model
try
BuiltInCategory.OST_Rooms
Hi everyone,
I´m trying to get the elements from linked model by the following code…Everything works fine but in “Elements from linked file in room” node from archi.lab package, seems does not work and return null.
What im doing is to get the walls from the link model by the rooms in the local model, then create wall finish by room
Any idea?.
Im working with Revit 2019.2 and dynamo 2.0.3.8811
