Hello, Dynamo, I’m just learning I can’t transfer the wall I created in dynamo to Revit, Is there something I’m not understanding or does this node have a bug that needs to be reported?
Hello think you need a native mass surface
thank you for your answer, but I don’t quite understand which node you are talking about
Try to import surface into revit with spring family instance by geometry as mass and then use element Faces…if you are In 2022 then use synthezise family insert node… hope it make sence…om not at pc In moment but Can give an exemple later…
I just started dynamo thank you for helping
You are welcome
and then you are come to the right place ![]()
