First, why does Dynamo Voronoi have broken cell?
Clearly, The reason is Scale.
How to fix?
I think it is better to have a range of 100 or more.
Look carefully at the pictures below.
related post:
I’m trying to create a voronoi pattern, but the cells end up disconnected and incomplete. See screenshot below. Basically, i am trying to create a 2D voronoi pattern that gets denser as it approaches an attractor curve. Please let me know if you see what the issue is here. Thanks,
[image]
Second, you can make the Voronoi short curves longer.
Voronoi naturally has a short line.
But It’s possible if you want.
Even if it wasn’t a short line correction, I had to at least want to adjust the polygon’s point position or line length.
So I created this script.
It may not be perfect hope it helps someone.
Please share if you know better way.
fix the short curve_share.dyn (76.0 KB)
related post:
Hello everyone,
I would like to control the edges length of a voronoi pattern, let’s say no edges smaller than 20 cm. Right now I am able to control the density of the points that define the pattern, in this way I can have a more dense/sparse pattern.
Can I define a rule that control the edges length of the pattern? Can I do it before the pattern is generated?
Something like “if edge length < 20 then extend it to 20”.
Here is a screenshot of the definition I have written so far, it is also a…
