n-nomi
1
Isn’t “Voronoi.ByParameterOnSurface“ different from the original definition of Voronoi?
Is there a way to create a Voronoi diagram without using Voronoi.ByParameterOnSurface?
I am trying to create a model using random points placed on a surface as seed points.
You can use Python but the result is almost exactly the same
import numpy as np
from scipy.spatial import Voronoi
points = list(zip(*IN[0]))
vor = Voronoi(points)
# Code from Scipy
# https://github.com/scipy/scipy/blob/main/scipy/spatial/_plotutils.py#L138
center = vor.points.mean(axis=0)
ptp_bound = np.ptp(vor.points, axis=0)
finite_segments = []
infinite_segments = []
for pointidx, simplex in zip(vor.ridge_points, vor.ridge_vertices):
simplex = np.asarray(simplex)
if np.all(simplex >= 0):
finite_segments.append(vor.vertices[simplex])
i = simplex[simplex >= 0][0] # finite end Voronoi vertex
t = vor.points[pointidx[1]] - vor.points[pointidx[0]] # tangent
t /= np.linalg.norm(t)
n = np.array([-t[1], t[0]]) # normal
midpoint = vor.points[pointidx].mean(axis=0)
direction = np.sign(np.dot(midpoint - center, n)) * n
if (vor.furthest_site):
direction = -direction
aspect_factor = abs(ptp_bound.max() / ptp_bound.min())
far_point = vor.vertices[i] + direction * ptp_bound.max() * aspect_factor
infinite_segments.append([vor.vertices[i], far_point])
OUT = finite_segments
p.s. they probably both use the same library from qhull.org
n-nomi
3
Thank you for the advice.
Will the line segments generated using this node be perpendicular bisectors of each generating point?
When using “Voronoi.ByParameterOnSurface“, there are some places that do not seem to be perpendicular bisectors.
I’m not sure, from the Qhull documentation
Qhull computes the Voronoi diagram via the Delaunay triangulation. Each Voronoi vertex is the circumcenter of a facet of the Delaunay triangulation
It’s always been by UVs @n-nomi - just convert the points to UV using Surface.UVParameterAtPoint.
The Dynamo team is tracking a bug for handling of edge conditions, but it’s been a lower priority for quite awhile now.
