Volume dashboard data in dynamo
Hello guys!
I’m not so expert in civil 3D (far from that) however I’m trying to manipulate property sets in dynamo, so in that way I can export data in an IFC file, my question is if there is a way to get valeus from volume dashboard in dynamo, so then I can set properties in extend data to export in the IFC.
I am not sure if that data is available.
In the next version of Arkance Systems Node Library there will be a node for bounded volumes calculation, so you can mimic the volume dashboard.
You can use:
.GetVolumeProperties()
on a database object, volume surface, in a python node. See my post here:
You can get the numeric values and assign them to property sets for your export. If you need any assistance and are willing to share any files I’d be happy to help.
I’m trying to use this pyhton in many surfaces at same time, however a error occurs, does this happens because this python just runs one surface per time?
What is the error?
If it is telling you the list has no attributes named … You have to loop through the input surfaces.
Sorry it was only set up for a single volume surface. Here is a solution for all surfaces with a name containing an input string.
VolumeSurface.dyn (15.1 KB)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
vs_name = IN[0]
volumeSurfaces = []
volumeSurfaceNames = []
adjustedCutVolumes = []
adjustedFillVolumes = []
adjustedNetVolumes = []
editor = adoc.Editor
with adoc.LockDocument():
    with adoc.Database as db:
            bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
            btrID = bt.get_Item("*Model_Space")
            btr = t.GetObject(btrID, OpenMode.ForWrite)
            for oid in btr:
                obj = t.GetObject(oid, OpenMode.ForWrite)
                if isinstance(obj, TinVolumeSurface) and vs_name.lower() in obj.Name.lower():
                    volumeSurface = obj
                    volumeSurfaces.append(volumeSurface)
                    volumeSurfaceNames.append(volumeSurface.Name)
            for volumeSurface in volumeSurfaces:
            	props = volumeSurface.GetVolumeProperties()
            	adjustedCutVolume = props.AdjustedCutVolume
            	adjustedCutVolumes.append(adjustedCutVolume)
            	adjustedFillVolume = props.AdjustedFillVolume
            	adjustedFillVolumes.append(adjustedFillVolume)
            	adjustedNetVolume = props.AdjustedNetVolume
            	adjustedNetVolumes.append(adjustedNetVolume)
            # Commit before end transaction
            t.Commit()
            pass
OUT = volumeSurfaceNames, adjustedCutVolumes, adjustedFillVolumes, adjustedNetVolumes
Update: there are nodes for this in the Camber package starting in v4.0.0.
Which Civil3D/Dynamo version do i need for this package?
2023
2022.1 or 2022.1.1
2021.3
2020.6 or 2020.6.1
This mode gives only the Net volume.
I mis the separate cut en fill volume and area of the bounded surface
Yes, indeed. I’ll add it to the wishlist :slight_smile:
