Multiple bounded Tin Volumesurfaces
Hello all,
I’ve been busy with implementing the Volume Dashboard functionality in Dynamo through Python as suggested in Getting surface information from C3D using Python topic and extending this with the method of Surface.GetBoundedVolumes.
So far I’ve managed to create a single bounded Tin VolumeSurface. It however gets problematic when I want to split one Tin Volumesurface with multiple polylines.
I’m running the following script:
__author__ = 'Jesus A Duran - jduran@moffattnichol.com'
__version__ = '1.0.0'
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbMgdbRep')
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for PropertySets
from Autodesk.Aec.PropertyData import *
from Autodesk.Aec.PropertyData.DatabaseServices import *
dataEnteringNode = IN
adoc = acapp.DocumentManager.MdiActiveDocument
ed = adoc.Editor
def get_tinvolumesurface_Vol(vs_name, base_surf, top_surf, vs_style, lay_name):
global adoc
if not isinstance(base_surf, list):
	base_surf = [base_surf]
if not isinstance(top_surf, list):
	top_surf = [top_surf]
if not isinstance(vs_name, list):
	vs_name = [vs_name]
pline_id = []
pline_obj = []
pline_indexvrt = []
pline_indexvrt_int = []
pline_obj_point = []
pline_obj_point_col = Point3dCollection()
base_surf_id = []
top_surf_id = []
vsid = []
vs = []
props = []
output = []
with adoc.LockDocument():
	with adoc.Database as db:
			bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
			btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
			#find polylines and determine vertices of those
			for oid in btr:
				pl = t.GetObject(oid, OpenMode.ForRead)
				if isinstance(pl, Polyline):
					if pl.Layer == lay_name:
						pline_id.append(oid)
			for i in pline_id:
				pline_obj.append(t.GetObject(i, OpenMode.ForRead))
			for j in pline_obj:
				pline_indexvrt.append(int(j.EndParam))
			for k, l in zip(pline_indexvrt, pline_obj):
				index = 0
				while index < k:
					pline_obj_point_col.Add(l.GetPoint3dAt(index))
					index = index + 1
			for oid in btr:
				obj = t.GetObject(oid, OpenMode.ForRead)
				if isinstance(obj, TinSurface):
					for b_name in base_surf:
						if obj.Name == b_name:
							base_surf_id.append(oid)
					for t_name in top_surf:
						if obj.Name == t_name:
							top_surf_id.append(oid)
				if len(base_surf_id+top_surf_id) is len(base_surf+top_surf):
					break
			if len(base_surf_id) is 0 or len(top_surf_id) is 0:
				return "Surface is not a TIN surface"
			for a in list(zip(vs_name, base_surf_id , top_surf_id)):
				vsid.append(TinVolumeSurface.Create(a[0], a[1], a[2], vs_style))
			for b in vsid:
				vs.append(t.GetObject(b, OpenMode.ForWrite))
			for c in vs:
				c.Rebuild()
				props.append(c.GetVolumeProperties())
			vs_bound = vs[0].GetBoundedVolumes(pline_obj_point_col)
			output = [{'Cut': vs_bound.Cut, "Fill": vs_bound.Fill, "Net": vs_bound.Net}]
			t.Commit()
return vs_bound
OUT = get_tinvolumesurface_Vol(IN[0], IN[1], IN[2], IN[3], IN[4])`
However, when I run this script with multiple polylines it gives the error “Unable to calculate volume, possibly illegal bounding polygon”. I guess this is due that the Point3dCollection has the points of two polylines, and not a single.
How can I create multiple bounded Tin VolumeSurfaces with multiple polylines?
Files can be found here
With kind regards,
Stan
I think you’re right. As written, the loop below will run through each boundary polyline and add the vertices to a one-dimensional list, right?
	index = 0
	while index < k:
	    index = index + 1
So then the GetBoundedVolumes method is trying to create a single polygon from all of the points, which fails. It seems like this block needs to be restructured so that you have a two-dimensional list with the points for each polyline as sublists.
But how do i get these Point3D’s in a two dimensional list?
If I add the script below, i do get the coordinates of the vertices split per polyline.
            for i in pline_id:
			for j in pline_obj:
			pline_obj_point_split = []
				pline_indexvrt_int.append(int(k))
				index = 0
				while index < k:
					pline_obj_point.append(l.GetPoint3dAt(index))
					index = index + 1
			total = 0
			for j in range(len(pline_indexvrt_int)):
				chunck_mylist = pline_obj_point[total:total+pline_indexvrt_int[j]]
				pline_obj_point_split.append(chunck_mylist)
				total += pline_indexvrt_int[j]
Results in this output:
output
These are however ‘python’ objects and thus need to be converted to a Point3D collection, maintaining the same list structure. How can that be achieved?
I was wondering if anyone has attempted to use the GetBoundedVolume in newer versions of Civil3D, I keep getting the error of "Unable to calculate volume, possibly illegal bounding polygon”. Even when I try with only one polygon.
