Dynamo > Property sets > IFC | for tin surfaces
hello guys,
I’m trying to extract data from surfaces to insert in property sets and then export the IFC file, is there any node in dynamo that extracts data from tin volume or surface properties?
does anyone has already worked with this flow?
Hi @k.honda,
What properties are you looking for?
cut, fill and net volume, all of that in tin volume surfaces
Did you see my reply to your original post?
There will be nodes available for this in the Camber package very soon.
sorry! it is exactly that! thank you very much!
FYI there are nodes for this in the Camber package starting in v4.0.0.
