Hello
I have developed a script (test 2) to create sheets and place views into sheets for my company.
The script works and places the views into the sheets with no issues (test 2 viewport title)
The strange problem that I have occurs when I try to combine this script with the previous one that I have done to create views from view templates (test 1).
This also works (creates the views + create the sheets + place views into sheets) but for some reason the viewport title offsets from the normal position with no apparent reason (test 1 viewport title).
I would like to keep the same result as “test 2 viewport title” without the offset viewport title. Any idea how to fix this please?
Thank you in advance.
David
As discussed by email also, the API does not have access to viewport title locations I believe (only from a ‘get’ perspective.). Replying here for anyone else’s convenience with similar issues.
Try ‘bottle-necking’ the code between each stage of the process (probably using a combined output list, a passthrough node, and a code block to split the list apart again after), this may get results more similar to the original 3 part scripted workflow.
I am having the same issue, did you manage to sort it out. My script creates views by room, then places them on sheets. If I do it separately then it works fine but when in one script it puts them all far away on the bottom left.
Any help would be appreciated.
James
Hi @j.wrightPYNCR
I indeed managed to sort it out. In my case, the problem was the scope box parameter. I think that is the reason why the viewport title offset from the viewport (because the crop region is associated to a scope box).
As @GavinCrump sugested, I used a “passthrough” node coming from my “sheets parameters” node and fed it before my “scope box set parameter” and that did the trick.
