I’m using a rhythm node that locate viewports based on selected one ,
but i got a displacement between parent one and childs ,
how to fix that?
Your sheet origin might be different between the two, (meaning someone moved the titleblock after creation).
Here is one way to see if your sheet is at 0,0,0
If it isn’t at 0,0,0
you could probably set the title block location based on the other one as well.
An option for handling this on your end is to create a translation between the 2 sheets.
