View.Viewport - Get Viewport from View
Hello Dynamo Friends :slight_smile:
Is there a direct way to get the Viewport from a View with the revit API?
I searched a lot but could´nt find something.
If there is no direct way then i have to get all viewports on the sheet, get viewIDs and compare.
Rhythm has a node for this, but whats the code?^^
Thankful for any advice :slight_smile:
Struggling with my workaround with a strange error:
My viewport has no View.Id? But why?
viewports = IN[0]
for viewport in viewports:
	viewId = viewport.ViewId
OUT = viewId
hi, I think you have to add this:
viewports = UnwrapElement(IN[0])
you can check this out:
https://forum.dynamobim.com/t/get-view-from-viewport-python/74707/2
Uh, you are so right! :smiley: Thank you!
So the workaround works, still interrested if there is a better way.
Here is the final code to get Viewports from Views :slight_smile:
# Get all viewports in document:
viewports = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
outlist=[]
# If Input is an item wrap it in a list:
if isinstance(IN[0],list):
	views = UnwrapElement(IN[0])
	views = [UnwrapElement(IN[0])]
# Get view ID of views:
for view in views:
	viewId = view.Id
	# Get View ID of viewports:
		viewportId = viewport.ViewId
		# output viewports that have the same view ID as the views:
		if viewportId == viewId:
			outlist.append(viewport)
OUT = outlist
