Get View From Viewport_Python
Hi guys
I am trying to get the views from a list of viewports using Python. I am struggling to find the method that does this. Appreciate any help. See my attempt below.
# CODE
# Get Viewports on Sheet
all_viewports = FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
all_viewports_flat = [ ]
for view in all_viewports:
	if isinstance (view,list):
		for v in view:
			all_viewports_flat.append(v)
		all_viewports_flat.append(view)
# Get Views
all_views = []
for viewport in all_viewports_flat:
	all_views.append(viewport.GetViews())
I have a node in Rhythm that gets the view for a viewport, that source code is here:
But, to recreate something similar in python it would be as follows:
clr.AddReference("RevitAPI")
#import the specific Revit API sections we need, you can also just do import* if you want
from Autodesk.Revit.DB import FilteredElementCollector,BuiltInCategory,Viewport, View
views = []
for viewport in viewports:
	viewId = viewport.ViewId
	views.append(doc.GetElement(viewId))
OUT = viewports,views
Thanks so much!
Yes I do have Rhythm downloaded but I’m trying to force myself to complete full scripts in Python. Much appreciated.
For sure! Learning python is great! I mentioned Rhythm more because it is open source and a lot of the code is fairly easy to translate. :slight_smile:
Is there anything for the reverse of this?
You mean to get the viewports from the views? Or are you referring to crop regions?
Yup to get viewports from views :slight_smile:
Can you provide some context so I can understand your goal?
Sorry dont worry about it, found out its something else
Take a look here:
c.poupin came up with a collector to iterate all viewports (I.e. Views on sheets) and it was rehashed to ID legends not on shets for deletion.
