I am trying to get view scale values using clock work View.Scale and put the values in shared parameter. I have 2 queries first is that the scale values is not 1: ratio its just showing 100,200 etc. and second is that i am getting error when i place the values in Shared Parameter. Below is the Snap. Thanks in advance.
Here is a way to achieve what you want, check out the notes I included in the image as well. You are able to get the scale value without a python script. I also assigned the value to a different parameter for the example.
It’s possible, as long as you added it as a project parameter as well. In your original screenshot you accidentally put the element on the set parameter as a string
