Using specific tag in dynamo
Hey all.
I’m using dynamo mostly for tagging pipes and ducts plans which is extremely exhausted to be tagged one by one but i need to use specific tag among my 15 tags families in model.
Is there a possible way to select it inside the dynamo or have to do it by select all in view and change the family after loading?
Grab your tags… then you could filter by name if you know the name of the tag.
Certainly. The best way to do so will vary by how your graph is currently set up though.
Hi @alaa.samy1919 do you have dynamoironpython installed for revit 23-24 its 2.7 version 2.5
Edit seems it archilab be sure you have installed the right version as well
