Hi, im using revit 2016, Dynamo 1.2 and the Package “Bakery 2016.11.1”.
Im trying to tag points in a list with text also in a list.
The lists have the same lenght.
The 3D-View in Revit is blocked.
Now i got an Error “There is no Tag avaiable”. So i think it has something to do with the family type i choosed.
I tryed different typs, but it diden’t work.
He…i stumbled over an solution/answer for my problem:slight_smile:
So i made a new revit project with english language and load my old dynamo project. All the familytyps are now also in english. So i must select new familytyps, because the old could not be found because of the language differences.
I had luck to select the right one and stumbled over some familytypes who functioned.
It depends on which familytype you choose at 1. and 2. They influence each other.
