Using matplotlib in dynamo to create images for Openseespy and Opsvis
Creating new topic for discussion from this thread below @Hadi.Moosavi
It is possible to get images using matplotlib by creating a temp file and loading it in using the DSCore.IO methods
Be warned it is quite the task to get all the python libraries working as openseespy has to be version 3.4.0.8 (python 3.9 / Dynamo 2.19) including a modification to the __init__.py file in the openseespywin folder to point to the tkinter install. Basic code below and image using an Opsvis example
import io
import os
import tempfile
import matplotlib.pyplot as plt
clr.AddReference("DSCoreNodes")
import DSCore
def image(fig):
    with io.BytesIO() as buf:
        fig.canvas.print_png(buf)
        with tempfile.NamedTemporaryFile(
            mode="w+b", prefix="IMG_", suffix=".png", delete=False
        ) as fp:
            fp.seek(0)
            fp.write(buf.getvalue())
            fp.close()
            # Dynamo Core Image
            filepath = DSCore.IO.FileSystem.FileFromPath(str(fp.name))
            image = DSCore.IO.Image.ReadFromFile(filepath)
            os.remove(fp.name)
    return image
# Clear memory
plt.close("all")
# Script here creating pyplot figures
OUT = [image(plt.figure(n)) for n in plt.get_fignums()]
another solution with PIL and io
import sys
import System
clr.AddReference('System.Drawing')
import System.Drawing
from System.Drawing import Bitmap
from System.IO import MemoryStream
import numpy as np
from PIL import Image
import io
import pandas as pd
from scipy import misc
face = misc.face() #ndarray 3 dimmensions
face2dG = misc.face(gray = True) #ndarray 2 dimmensions
def plt2arr(fig):
    need to draw if figure is not drawn yet
    fig.canvas.draw()
    rgba_buf = fig.canvas.buffer_rgba()
    (w,h) = fig.canvas.get_width_height()
    rgba_arr = np.frombuffer(rgba_buf, dtype=np.uint8).reshape((h,w,4))
    return rgba_arr
def convertToBitmap2(npImgArray):
    bitmap_ = None
    # remove alpha
    if npImgArray.ndim == 3 and npImgArray.shape[-1] == 4:
        npImgArray = npImgArray[:, :, :-1]
    # convert to PIL Image
    if npImgArray.ndim == 3:
        image = Image.fromarray(npImgArray, "RGB")
        image = Image.fromarray(npImgArray, "L")
    # convert to Python ByteArray
    byteIO = io.BytesIO()
    image.save(byteIO, format='BMP')
    byteArr = byteIO.getvalue()
    # convert to Net ByteArray
    netBytes = System.Array[System.Byte](byteArr)
    with MemoryStream(netBytes) as ms:
        bitmap_ = Bitmap(ms)
    return bitmap_
# Example 1 : plot sin and cos wave
fig = plt.figure()
ax = fig.add_subplot(111)
x = np.linspace(-np.pi, np.pi)
ax.set_xlim(-np.pi, np.pi)
ax.set_xlabel("x")
ax.set_ylabel("y")
ax.plot(x, np.sin(x), label="sin")
ax.plot(x, np.cos(x), label="cos")
ax.legend()
ax.set_title("sin(x) and cos(x)")
img_sin_cos = plt2arr(fig)
bitmap1 = convertToBitmap2(img_sin_cos)
# Example 2 : convert img scipy
bitmap2 = convertToBitmap2(face)
bitmap3 = convertToBitmap2(face2dG)
# Example 3 : plot a Dataframe
file_name = "https://raw.githubusercontent.com/uiuc-cse/data-fa14/gh-pages/data/iris.csv"
df_iris = pd.read_csv(file_name)
# ax = df_iris.plot(kind="scatter", x="sepal_length", y="sepal_width", figsize=(10, 8)
ax = df_iris.plot(kind="scatter", x="sepal_length", y="sepal_width")
img_iris = plt2arr(ax.get_figure())
bitmap4 = convertToBitmap2(img_iris)
OUT = bitmap1, bitmap2, bitmap3, bitmap4
A little bit of digging through source code… matplotlib has a private method _print_pil
def image2bitmap(fig):
        fig.canvas._print_pil(buf, fmt="BMP", pil_kwargs={})
        byte_array = System.Array[System.Byte](buf.getvalue())
    with MemoryStream(byte_array) as ms:
        bitmap = Bitmap(ms)
    return bitmap
Nice find
This is very interesting.
I tried. I get an error saying the file is being used by another process. See below.
Is it the plt that is still accessing it?
Posting the code would be easier than trying to guess what is above line 19
Read the full warning and try and work back
Line 38 is incorrect - change to fp.close() to call the method
Uncomment import clr and add the following lines if they are not present above
import io
import tempfile
clr.AddReference("DSCore")
import DSCore
my bad. it was the fp.close() typo. I think I was expecting it to give an error if that was the issue. Thanks a lot!
