I was wondering if you would be able to help me with a problem I am trying to solve in Revit. I am new to dynamo and I want to be able to do this, in order to make my life easier at work. So I work for an electrical engineering consultant firm and we work on electric panel schedules and one line diagrams. Would it be possible to somehow link the electrical panel to the one line diagram? Right now, the one line diagram is just line work so we would need to make that a smart family. But would it be possible to see the changes from the one line diagram to the electric panel schedule using dynamo.
@Jonathan_MONTOYA, you can use Dynamo to exchange data between different family categories. You could use Detail Item Families for the one line diagram elements. Make sure your parameters are the same parameter type than then parameters in your electrical equipment.
