I’m attempting to use a custom node I created that places an instance based on geometry determined in the graph. I’m using Springs “FamilyInstance.ByGeometry” node to place the instances.
I’m using the custom node so that I can run the script for multiple areas at the same time and this seems to be the best way to loop a Dynamo graph.
Here is what happens when I click run. First the first instance gets placed with the correct geometry and I see the following:
A second later, the second instance is placed with the correct geometry; however, my first instances geometry is changed.
Has anyone encountered this issue before? I have tried using Beakers “Utilities.BakeElements” node but this doesn’t work for my case. Any help is appreciated! Thanks in advance
