I have created a custom node that generates a warren truss geometry, analyses it, and evaluates the results. when I run the custom node it gives me results but it doesn’t plot the truss. However, when I use the same nodes in the custom node in a different file, dynamo and RSA plot the truss shape and provide results. Has anyone come across this before?
Thank you in advance.
@benameram It might be because you didn’t provide any output for the geometry.
Try providing an output for your geometries and check.
Thank you @AmolShah for your help.
What about the geometry in Robot Structural analysis RSA. Because my script generates the geometry in Dynamo and then sends it to RSA for analysis. But I cant see the geometry in RSA. Do I have to provide the output for that too?
@benameram I don’t work with RSA so won’t be able to help you on that!
Please create a new topic and see if someone knows the answer.
