Hi Guys
I have a quick question. I am using the spring node for family instance generation based on a geometry generated in dynamo. The node is working for me, but the family instance position (X, Y, Z coordinates) doesn’t match the position of the geometry generated in Dynamo. Is this how it was supposed to work?
I any suggestions on how to correct this?
I can use the family instance.by Point to place it later to the desired position, but maybe I could avoid this if I solve this issue.
GREAT JOB, SPRING!
Looking forward to hearing from you.
Cheers,
Nery
