Hello guys,
Referring to image below, is there a way for me to automate changes in my generic annotation. Because everytime i issue the drawing, i need to update each instance of the stamp (generic annotation).
At the moment, I have a script to modify one parameter only but as you can on the image above, it has 3 parameters (for day, month and year).
Here is my current script, btw, can this be simplified?
This is a list levels and lacing exercise. Try this:
Set the graph to manual if it isn’t already.
Build a list of the parameter names(so app date and approved by), and a list of the values (so the date and the username).
wire those into a single Element.SetParameterValueByName accordingly. Delete the other one (or freeze it if you are worried this might mess something up).
Set the lacing to longest and the element input to @L1. Hit run.
Hi Jacob, thanks for the reply. i tried what you say, hopefully this is correct.
The output in revit is not correct. Please see my next reply.
Here is the output @jacob.small
Try other lacings and list level settings.
Got it! Used @L2 and Longest.
Thank you @jacob.small!
Great news! Please post or mark a solution so others can also learn from this thread.
