I run script and have Numbers as results =76 depends to what parameter I am writing to value is different?
when I save to parameter Power or Wattage I have 7.06
when I save to Number I have 76?
why
1W in SI base units is equal to kg.sqm.s^(-3)
but the base unit of length in Revit is ft
1sqm = 10.76391sqft
76 / 10.76391 = 7.0606
Issue Solved
Thanks Vikram I REALLY appreciated your help and support! without this I would be stuck forever. This is very kind,
…so “unit-less Revit” is myth… ok now it is clear …all units need are transformed to Imperial …good to know I guess I will use most of parameters as TEXT to get it easier I will have to always really watch units… and recaulcated back to metric but there could be rounding issue I guess
