It would also be interesting to get some feedback over this:
Hi @Dimitar_Venkov, How can I access to the old forum? Thanks
@Einar_Raknes I tried this definition you had written some time ago… I don’t get how to fix this issue with this line
for e in elements:
_ famdoc = doc.EditFamily(e)_
_ fec = FilteredElementCollector(famdoc).OfCategory(BuiltInCategory.OST_IOSModelGroups).WhereElementIsNotElementType()_
he prints out this error out of the definition:
Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. _
_ File “”, line 31, in
Exception: The document is currently modifiable! Close the transaction before calling EditFamily.
Dynamo is not the best tool to edit different Revit documents, but you can try to add TransactionManager.Instance.ForceCloseTransaction() before the for loop.
Thank you. If it still doesn’t, Should I unload the different documents I have linked in the project or what?
Nope. Encountered the same issue, what shall I do? I tried to unload the other links in the project but no luck with that
I tried also to use your old version (the one without the reloading step) and neither that worked, gave me this
Exception: The model could not be saved: (COleException 0x80030002)
