Unable to permanently change a parameter group
I was trying to obtain the same thing as this post, i.e. changing parameter groups and noticed the same error: once I save the family or the project then the parameters do not remember that they were moved and go back to their original state.
This is a similar post with a different code posted by @Konrad_K_Sobon but with the same concpet: OLDparameterDefinition.ParameterGroup=NEWgroup
I tried both in the project and the family environment and could not permanently save the changed group, i.e. if I closed and reopened the file the parameters did not change. However if I did it by hand it worked. It seems like we are missing some sort of “update” button, or maybe we have to trick revit in thinking that the edit was done by a human and not by python.
Cattura
In the project environment:
clr.AddReference('RevitAPI')
import System
pgINstr=IN[0]
pgOUTstr=IN[1]
#From the input strings find the corresponding BuiltInParameterGroup
bpgs=System.Enum.GetValues(BuiltInParameterGroup)
for bpg in bpgs:
	if str(bpg)==pgINstr:
		pgIN=bpg
	if str(bpg)==pgOUTstr:
		pgOUT=bpg
#Create a list with all the project parameters
params = []
iterator = doc.ParameterBindings.ForwardIterator()
while iterator.MoveNext():
	params.append(iterator.Key)
#Change the parameter group of all parameters in the desired paramgroup
pchanged=[]
for pdef in params:
	if pdef.ParameterGroup==pgIN:
		pdef.ParameterGroup=pgOUT
		test=pdef.ParameterGroup
		pchanged.append(pdef.Name)
	#TransactionManager.Instance.ForceCloseTransaction()
OUT = pchanged
In the family environment:
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
pgGroupStr=IN[0]
pgGroupStr2=IN[1]
for bpg in bpgs:
	if str(bpg)==pgGroupStr2:
		pgGroup2=bpg
	if str(bpg)==pgGroupStr:
		pgGroup=bpg
rtn=[]
params=doc.FamilyManager.Parameters
for p in params:
	if p.Definition.ParameterGroup==pgGroup:
		rtn.append(p)
		p.Definition.ParameterGroup=pgGroup2
OUT=rtn
I tried playing around with ForceCloseTransaction() instead of TransactionTaskDone(), and inserting the transaction in the for loop but nothing changed.
I am not talking about changing a parameter group in a family, uploading it (again) in a project and noticing that the group does not change: this is a well known issue regardless of what Autodesk says: link
A really horrible “workaroud” I found is the following:
  • For the project environemt: run the script, create a new file(rvt or rte template, as in my case), and transfer the standards (the parameters in my case) to the new file.Now use the new file…
  • For the family environment: run the script, create a new file(rvt or rte), load and close the family in the project, export the family from the project.
This is the second time I found such a behaviour (recently I could not permanently change some MEP settings) and would love to understand what line of code I am missing
Hi @GregX have you any news about for this task?
Cheers
In your project you can loop your desired parameters and write something like this:
for p,g in zip(parameters,desidered_groups)
	p.GetDefinition().ParameterGroup = g
Hi @GregX thank you for the information,
I’d like to change the type of “Group parameter under” for some of my Project Parameters (project parameter or shared parameter) available in my revit project
it’s possible with GetDefinition method?
Thanks for your efforts
Cheers
Hello @paris could you show what you tried? This forum is to help each other and give hints on something you already tried, people aren’t going to do all the work for you
Hi @GregX
thanks for your answer, yes of course, below the error into my python code:
_Example_change a parameter group_D203.dyn (20.4 KB)
Cheers
You are nearly there, here are some corrections:
  1. When you bring elements from dynamo to python you have to “unwrap” them, just to “convert” them from “dynamo elements” to “revit elements”. You can do that simply by adding this:
    parameters=UnwrapElement(IN[0])
  2. Next, the error your python gives you is that you are feeding only one parameter group (a single item, not a list), while the iteration thinks that you will give it many parameter groups as parameters. You can either:
    a) repeat your desired parameter group:
OR
b) simply tell python to read only one parameter group:
desidered_group=IN[1]
for p in parameters:
p.GetDefinition().ParameterGroup = desidered_group
(there should be a tab space at the beginning of the last row)
Hi @GregX , awesome, thaks for you answer, you’re right, now it’s work, but if I close the project and after I reopen the project then the parameters do not remember that they were moved and go back to their original state, it’s maybe a bug?
Cheers
Yes that was my problem at the beginning of this thread. I then used the same code but with shared parameters (and in revit 18 maybe) and I think it worked, maybe try testing it with project parameters and shared parameters to see if there are any differences?
I don’t remember finding out other differences, maybe also the revit version?
Hi @GregX , I’m on Revit 2019 and it doesn’t work as expected, I’m looging for something with Transaction or another method.
Thanks very much
Have a good day
Cheers
Hello
try with this method (tested on Revit 2021)
import System
lstNamepara = IN[0]
pg = IN[1]
outDef = []
newgroup = System.Enum.Parse(BuiltInParameterGroup, pg)
for namPara in lstNamepara:
	bmap = doc.ParameterBindings
		internalDef = iterator.Key
		binding = iterator.Current
		if internalDef.Name == namPara:
			bmap.ReInsert(internalDef, binding, newgroup)
			outDef.append(internalDef)
			break
OUT = outDef
Hi @c.poupin , great! It’s very impressive, on Revit 2019 it’s working as expected but only for shared parameters and not for project parameters, is there a reason? Thank you very much
Have a good day.
Cheers
It’s a Revit API Limitation, Insert() and ReInsert() parameter methods works only with externalDefinition (so need SharedParameter )
Hi @c.poupin
now I understand better, thank you very much for the help on the python node and for the clear explanation.
Have a good day
Cheers
Hi, @c.poupin
The code doesn’t work, could it be related with updated version of Python inside Dynamo?
Hi, it would be helpful if you could provide the error you encounter when running the code
Hi @denisyukj
Which Revit version are you using, there is any error message?
