ParameterGroup as Revit.Elements
Good day,
this is possible -get ParameterGroup as Revit.Elements ?
i would like to get Names of them like in Revit
Sorry, could you please rephrase the question?
BuiltInParameterGroup is havent Description or Name so this is trouble
I’m also lost… the Parameter.Group node isn’t sufficient? Can you post a rvt and dyn so we can understand what you’re after?
its need to get names as in Revit of all ParameterGroup (PG_)
Get all PG_
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
import System
OUT = [i for  i in System.Enum.GetValues(BuiltInParameterGroup)]
Hi @til.shviger
its Very Good news ! .I am pleased that this is a possibility
@Kulkul
thanks again for your help :v::slightly_smiling_face:
@til.shviger No Problem :wink:
@Kulkul
you are can use new avatar :grin:
I try to use this code, but after writing it down, I have no result.
clr.AddReference('RevitAPI')
import System
bip = System.Enum.GetValues(BuiltInParameterGroup)
pdata = list()
for b in bip:
    try:
		pdata.append((b,LabelUtils.GetLabelFor(b)))
	except:
		pass
#Weisen Sie Ihre Ausgabe der OUT-Variablen zu.
OUT = pdata
this is the resultDynymo_BuiltInGroup
can Anybody help me?
THank you
Heinrich
What are you get in bip ? may be you are get empty list ? try :
import System
OUT = bip
Python is indent sensitive, try recreating all indents in your script :slight_smile:
Thankyou for this post. I don’t have words to thank you Mr. @Kulkul. Your script has saved immense time for me. Thank you so much sir. God bless you.
~J
