Set Parameter to Vary by Group Instance
Might be useful to people…
This is limited by the types of parameter which are allowed to vary by group instance, this does not include Yes/No or Length.
Thanks to @jeremytammik and anyone else who has done work in this area.
Mark
import System
from System import *
clr.AddReference('RevitAPI')
dataEnteringNode = IN
keyWord = IN[0]
def isInstance(definition_Name):
	#for some reason, returning the name of the Key in the bindings iterator
	#fails sometimes and says item can't be managed? so then restart Revit
	#the list of parameters in doc.ParameterBindings is only the ones which are
	#added in the Project Parameters box, so you're not getting ones which
	#just exist in families
	#this is the only way to see if a parameter is 'bound' to the doc as
	#a type or an instance parameter
	bindings = doc.ParameterBindings
	it = doc.ParameterBindings.ForwardIterator()
	defs = []
	value = False
	while(it.MoveNext()):
		d = it.Key
		b = it.Current
		if d.Name == definition_Name and b.GetType() == InstanceBinding:
			value = True
			break
	return value
def canBeEditableInGroup(parameter):
    parameter_Type = parameter.ParameterType
    variable_Parameter_Types_List = [ParameterType.Text,
                                     ParameterType.Area,
                                     ParameterType.Volume,
                                     ParameterType.Currency,
                                     ParameterType.MassDensity,
                                     ParameterType.URL,
                                     ParameterType.Material]
    if parameter_Type in variable_Parameter_Types_List:
        return True
        return False
# Place your code below this line
output = []
#catch anything that doesn't work and output the error
sPs = FilteredElementCollector(doc).OfClass(SharedParameterElement)
try:
    errorReport = None
    #begin transaction
    for sP in sPs:
        #we are interested in the shared parameter 'definition'
        #the 'definition' is a container of the shared parameter
        #that holds the information about whether
        #the parameter is variable by instance in a group
        #we only want the shared parameters with our key word
        #we only want them if they are a type which can vary
        #we only want them if they are not already true
        #we only want them if they are instance parameters
        definition = sP.GetDefinition()
        varies_Query = definition.VariesAcrossGroups
        if keyWord in definition.Name and canBeEditableInGroup(definition) and isInstance(definition.Name) and varies_Query != True:
            try:
                definition.SetAllowVaryBetweenGroups(doc, True)
                output.append("Success: " + definition.Name + " can now vary across group instances")
            except:
                import traceback
                errorReport_SP = traceback.format_exc()
                exception = ' does not support the specified value of allowVaryBetweenGroups'
                if exception in errorReport_SP:
                    output.append("Failure: " + definition.Name + "cannot be set to vary between groups")
                    output.append([definition.Name, errorReport_SP])
    #finish transaction
except:
    import traceback
    errorReport = traceback.format_exc()
if errorReport == None:
    OUT = output
    OUT = errorReport
OUT = output
sorry does not work, says Empty List the result, I tried in Revit 2023 with ironpython 2.7 and cpython3 engine too, it worked like this:
import traceback
# Get current Revit document
# Get filter keyword from Dynamo input (e.g., "Planification_")
keyword = IN[0]
# Returns True if a shared parameter with this name is instance-bound
def isInstanceBound(definition_name):
    it = bindings.ForwardIterator()
    while it.MoveNext():
        if it.Key.Name == definition_name and isinstance(it.Current, InstanceBinding):
            return True
    return False
output = []
try:
    # Get all SharedParameterElement definitions in the document
    shared_params = FilteredElementCollector(doc).OfClass(SharedParameterElement)
    for sp in shared_params:
        try:
            definition = sp.GetDefinition()
            name = definition.Name
            if keyword in name:
                output.append("Processing: {}".format(name))
                if isInstanceBound(name):
                    # Attempt to force vary-by-group setting
                    output.append("✅ Set 'vary by group instance' = True for '{}'".format(name))
                    output.append("⚠️  Skipped: '{}' is not instance-bound.".format(name))
        except Exception as innerEx:
            output.append("❌ Error processing '{}': {}".format(name, traceback.format_exc()))
except Exception as outerEx:
    TransactionManager.Instance.ForceCloseTransaction()
    output.append("❌ Transaction failed: {}".format(traceback.format_exc()))
# Return log output to Dynamo
OUT = output
