Is it possible to create new Parameter Group?
I want to create new parameter group.I have some project parameter under General group,want to group them under new parameter group named “EDI”.
Hi @bikashseas
You don’t need Dynamo for this. Its easy in Revit Just select the parameters and click on “Move” to move your parameters.
@Kulkul
@bikashseas I don’t think its possible.
I want to know if I can extract the parameter group list at least …
clr.AddReference(“RevitAPI”)
import System
#Assign your output to the OUT variable
OUT = System.Enum.GetValues(BuiltInParameterGroup)
Thank you for your reply but I don’t realy know how I can use it.
Put it into the node of phython script or something?
If you can give me little more details I would appreciate it.
Best.
Yuki
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
Copy and paste above codes inside python script.Just run it.
Enjoy
Hi, where did you add the new parameters group in the script?
Hi, did it work? I do not see where and how you can add new groups to the list. Let me know please!
No,its not possible
Hello,its not possible…
you miss understood the question!!
