Unable to loft
unable_to_loft
Hi!
I’ve been trying to made a loft between two sections and so far i can’t. Can anyone please indicate me a workaround?
Thanks!
Error : Warning: Solid.ByLoft operation failed.
Unable to loft! : BAD_UV_SKIN_DIR – Surface U and V derivatives are in the same or opposite direction
Hi Marques,
What method did you use to generate your curves?
2015-03-27_101633
Problem solved, thanks :wink:
Hi
I am having similar problems. I’m using Rhynamo to import the outline geometry. The polycurves are all pointing in the same direction, closed, etc but I am getting the same error:
Unable to loft! : BAD_UV_SKIN_DIR — Surface U and V derivatives are in the same or opposite direction
I’ve rebuilt the polycurve by extracting each sub curve, getting its start point and then creating a new polycurve by points by the problem persists. Any suggestions?
Dynamo issue
I am facing the same issue now . how did you manage to do at the end? were you successful?
sorry its been so long now I don’t remember.
Facing the same error now. Does anyone have suggestions?
Same here :frowning:
@Aparajit_Pratap is it possible to shed some light on what this error message means for people in this thread :slight_smile: ?
@danail.momchilov can you share the graph for us to take a look at exactly what is failing and why?
hi Paul, did you solve the problem?
I met with the same error message yesterday. After reading some other posts, I found there a solution for my problem. I put a List.Transpose node right before the Surface.ByLoft node and now it works well.
