Hi!
I’ve been trying to made a Solid, by loft, between 2 sections, with multiple guidecurves…
I am getting this error : “Warning: Solid.ByLoft operation failed.
Unable to loft! : SKIN_SECTION_FAILED_JOINING_PIECES – Failed joining the skin section pieces”
Can someone help me please?
Marques, are you using a daily build of dynamo as may be an error with that particular build. Other than that check how you are feeding in your guide curves. In my example I have flattened the list and it works fine, but alternatively it also works without flattening, giving a slightly different result.
